Charged wrote:I believe the rev2 block is stronger as well.
craig wrote:Charged wrote:I believe the rev2 block is stronger as well.
myth.
Rev 1/2 blocks appear to go around the water pump area.Rev3+ tend to crack between cylinders 1&2.
Luck of the draw.
I'd source a rev 3 turbo rear clip if poss.If not, rev 2 block, rev 3 head, ecu, turbo, fuelling etc.
TheLepresean wrote:Good evening all, starting to look more seriously at doing a turbo conversion on my UK Rev5 NA and Rev3+ clips seem very thin on the ground and expensive when they do come up.My question, is are Rev2 clips THAT much worse? Extra 20bhp, decent head gaskets and a higher resale value
- but I plan on taking the car to around 300bhp and keeping the car either way.
Does the extra money spent gaining that 20bhp back overrule the extra price of a Rev3 clip.
