Wind noise in cockpit, REV1 turbo.
As above, wind noise coming from both sides of the car, sounds like around the tweeter speaker area, any others have this issue and how is it solved?
Toyota MR2
- 3S-GTE
- 1991 Turbo
- Yellow
Re: Wind noise in cockpit, REV1 turbo.
got this on a rev 4 but only on the driver's side.
Only when the wind is strong.
Must be some foam has disintegrated over time.
Going to check it out when fitting new speakers.
- IMOC Moderator
Make sure the windows are going all the way up.
Over time the runner wear etc.
Remeber the windows can be adjusted in/out as well for tightness against the seal
sheppy wrote:Make sure the windows are going all the way up.Over time the runner wear etc.
Surely if it was the window not tight to the seal I might notice leaks? As it stands there is absolutely none.
Toyota MR2
- 3S-GTE
- 1991 Turbo
- Yellow
Aaaaah I know there is a fix for this somewhere possibly with pictures.
I will see if I can find it.
- IMOC Moderator
kurkjones wrote:sheppy wrote:Make sure the windows are going all the way up.Over time the runner wear etc.
Surely if it was the window not tight to the seal I might notice leaks? As it stands there is absolutely none.It's just very confusing.
Just trying to eliminate any possibilties, without being in your car and hearing for myself I really can't say for certain.
sheppy wrote:kurkjones wrote:sheppy wrote:Make sure the windows are going all the way up.Over time the runner wear etc.
Just trying to eliminate any possibilties, without being in your car and hearing for myself I really can't say for certain.It is a good starting point though as it costs nothing to check/adjust.
Yeah mate it's definitely worth me checking! Thanks.
Toyota MR2
- 3S-GTE
- 1991 Turbo
- Yellow
Chumbaside wrote:gnzyza wrote:the wind noise is normally one of three things.
Window adjustment
sealing behind tweeter cover
or front window edge
(borrowed from member
- Moo)
[url]http://i78.photobucket.com/albums/j93/Moo_22/VelcroMirrorRepair2.jpg
[/URL]
Good to know man.Will need to give it a shot, at first I thought the problem was behind the cover in behind the speaker itself? I put some sound deadening in there but didn't make much difference so will try the cover seal.
Thanks.
This solved my issue- been fine for years ever since! Nice to find a cheap fix on an MR2
Toyota MR2
- 3S-GTE
- 1991 Turbo
- Yellow
