faulty oil level sender?
drunknmunky
Post by drunknmunky »
Hi people,
just had my oil level light come on, my own fault, hadn't checked it for a while, was just bang on minimum mark on the stick, so put oil in so its now on full. problem is, oil level light still keeps coming on after about 10 seconds of the car running.
How can I check oil level sensor is working? or could this be more serious?
thanks
Andy
drunknmunky
Re: faulty oil level sender?
sorry, should have said its an n/a, not a turbo.
caldridge7
Post by caldridge7 »
I wouldnt say its serious...id say start the car and let it idle and warm up and just listen to the engine for any knocking or anything like that... overall just see if the light goes out.
kind regards
Charlie
caldridge7
God didn't read your message properly sorry!
that's bad that oil light is not "top up your oil" its a oil pressure light...meaning i believe that oil is not circulating through then engine properly which is BAD.
Hopefully someone will either agree with me or prove me wrong but i think that's right.
mr2garageswindon
Post by mr2garageswindon »
It'll prob go off after you hit a bump or two. Likely its just stuck in the lowest position.
drunknmunky
caldridge7 wrote:God didn't read your message properly sorry!
It is the yellow light on the right side of the dash, not the red light on the left. So that's level surely, not pressure? I hope.
Seems to be intermittently coming on and off, stays on for a few seconds, goes off a few seconds, back on etc.
madbasshunter
Post by madbasshunter »
The oil level sensor is known for failing and cost a fortune to replace, sure you can just unplug it :wink:
Bit more info here
http://www.imoc.co.uk/forums/viewtopic. ... vel+sensor
RyanRs wrote:
Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously , you don't know the answer to this? and you call yourself a car mechanic :shock:
drunknmunky
ok thanks guys
