I have a question about thermostats.
I believe my thermostat has started sticking open from startup, as the car takes so much longer to heat up and on my commute to work
If it is the thermostat, would the following be okay from eurocarparts?
http://www.eurocarparts.com/ecp/c/Toyot ... c67&000325
http://www.eurocarparts.com/ecp/c/Toyot ... f55&000325
I'm aware these are probably shoddy, but has anyone actually used them? The reason they appeal to me is because I can have them delivered by tomorrow and it can be fitted over the weekend.
Let me know your thoughts.
On a side note, this started happening after driving home, I saw two lights appear.
Thanks for your time if you choose to reply.
99ron
