I'm wanting to overhaul all of the rusty control arms, hubs, tensions rods etc.
on my project MR2 this weekend.
Is it as simple as removing them, washing and degreasing then getting busy with a wire brush?
Then following with something like POR15
(several layer system iirc) and replace bushes?
I think it's probably worth just replacing the steering tie rods and tie rod ends because they look like the threads will strip if they're adjusted now lol
Also I noticed while under the car yesterday that the OS tension rod is threaded about 20mm differently to the NS rod
- is this likely to be a mix up of PAS/non-PAS hubs as I've read they're different sizes?
Finally does anybody know is it possible to still buy new control arms, tension rods and trailing arms etc.
from Toyota? I couldn't find any part numbers, however it appears there are a few aftermarket performance tension rods available from RHDJapan etc.
I'm just not sure how to tell if something is
'too rusty'
- obviously OEM arms will cost a fortune though lol
