My theory is the engine heat dried out the coil enough for it to work again but I knew I needed a new one.
Now onto the crux of my post.
First up is my old knackered coil This is a rev 1 with 7mm ht leads so the part number is specific to that.
Now on those pics you can see the crack on each side and the rusty delamination on the underside.
Fitted the new coil and she fired straight up.
Now on to pointers
Be careful when releasing the electrical connectors.
Be gentle with the king lead as they can be damaged especially the L shaped end at the dizzy
When I went to remove the coil from the bracket I found the machine screws wouldn't budge, not 1 of the 4.
So You may need 4 off M4 x 15mm pan head machine screws
On refitting I ran a tap through the threads on the bracket and added a little copperslip.
Whilst the bracket is off the firewall also remove the igniter and clean up the mounting points on the bracket for the coil, ignitor and bolts.
Access to the coil is improved by releasing the fuse box from its mounting points.
Basically this 10 minute job could turn into a couple of hours
HTH
