front bonnet wont open common problem how do i sort it ?
toymotor
Post by toymotor »
94 MK2 rev 3 front bonnet wont open cable is not snapped but will not open
I can see the latch from under the car but which bit releases the bonnet ?
common problem how do i sort it ? desperate need it for work
tiff_lee
Re: front bonnet wont open common problem how do i sort it ?
Post by tiff_lee »
Is the latching mechanism dis-engaging when you pull the release lever? get someone to pull the release lever while giving the bonnet a 'tap' around the catch area and see if it pops.
archangel
Post by archangel »
Has the latch made the pop sound and isn't opening? Maybe try disconnecting the cable from the lever in the driver footwell and pulling the cable with some plyers on the end to get it to pop.
Rev1 Tubby, Garrett GT3071R, Motec M4 EMS, 880cc delphis, Rev3 turbo port polished built head/cams/titanium retainers, shim under buckets, HD springs, etc., rear bumper mounted intercooler, and vanilla air freshener.
Draven
Post by Draven »
Get someone to push down on the bonnet while you use a pair of plyers to pull the release cable.
I had this on one of my MR2s.
Then make sure the cable is nice and tight and has some grease on the latch before closing the bonnet again.
Mullen
Post by Mullen »
As Draven said, keep the latch lubed in future. A sticky latch can come undone on its own too as well as preventing opening.
