Need your help reassembling under trays
Rob
Post by Rob »
I've got the front trays on and also the front arch liners but I'm struggling with hoe they all join and also how they join with the lip spoiler. This means 3 layers joining at certain points
I've got 2 clip types; c clips and s clips, am I right in saying that the s clip are for 3 layers meeting?
Any pictures of the tray areas just in front of the front wheel on a fully assembled car would be a huge help.
raptor95GTS
Re: Need your help reassembling under trays
Post by raptor95GTS »
a quick online search found plenty of pictures, for example the front undertray at the radiator http://www.turbomr2.com/MR2/HowTo/Radia ... tor-01.htm
Rob
Post by Rob »
Thanks - I found those pictures too but they don't show how the front trays, arch liners and radiator side cowls all come together as 3 different layers and what fixings are used.
I went to the scrappy in the end and had a look at the car there. All back together now.
For future reference - 2 layers is held together using the plastic 'C' clips and 3 layers uses the plastic 'S' clips. The S clips on teh wings has the rounded part of the clip external with a stainless screw and the S clips underneath has the rounded part behind the outer layer with a ferrous screw connecting through from the underside.
