Thanks for the replies guys.
In the end the bolt came free.
I used some bolt freeze stuff, called super crack ultra, sounds like quite a night out I know but I assure you its not a class A drug.
Overall I think a combination of a single hex socket
(as to not round the bolt) using Plus gas over a week or so and finally trying that freeze stuff allowed the bolt to come free without too much hassle.
Still had to hammer at the alternator to move it though, as it was an extremely tight fit in the mount.
I don't look forward to getting the new one in.
I managed to get the alternator out of the top of the engine bay, although the mount had to be removed, fortunately I was able to remove the mount as well from under the car to repaint it.
Hopefully after getting all the rust off, degreasing the parts, repainting and reassembling with ensis oil should reduce that amount of corrosion appearing again.
mr2magic, you are correct.
There is a very badly placed bolt in the centre of the mount right behind the alternator.
Suffice to say, that bolt will not be going back in just incase a similar situation occurs.
I'm sure the surrounding 4 nuts and bolt will suffice for the forseeable.
Again, thanks for the insight.
