Sorry for more questions, as i'm just trying to establish what bits were put together for this 4agte.
For example, my 4agte is currently a later spec with oil squirters 4agze block from a corolla, but its runs on earlier AFM electronics from an MR2 supercharger.
Is the block later spec smallport 4agze and does it come with a smallport NA inlet manifold, or does it still use the supercharger inlet mani?
What, if any, intercooler does it come with?
If it uses the later electronics, has the loom already been adapted for an MR2?
What is this injector rail that it needs?
Also, is the turbo a genuine garrett t25, or a chinese copy?
Finally, is the piping all ready to fit, or is it a set of pipes that need to be cut and adjusted?
Phew
