L reg 1993
78k miles will go up as i still use it
Mot 16th October 2016
Lots of work done in the last few weeks.
Sills Repaired Arch repaired, needs shaping and painted.
Timing belt and water pump replaced
Alternator belt replaced
Thermostat replaced
Oil and Filter service.
New Downpipe fitted
New rear caliper.
Bodywork is a bit tatty wont take much to clean up, and it requires a new rub strip for the nsf.
Inside need tidying also seats are in great condition, the glovebox and steering wheel are a little worn.
usual crunch in 3rd gear if your pushing it before its warmed up.
Drivers door a little rusty along the bottom.
Comes with clear side repeaters and corner lights.
Double din Headunit
The wheels have been plasti dipped, just peels off if you want to refurn them.
No timewasters, if you want to test drive it bring the cash and proof of insurance.
Located in Stirling, Scotland
