friday i went on the first ride for 9 months with my car finally got it fired up,
drove fine on low rpm no hesitations or anything but when i was giving it full throttle too see how it responed on high rpms.
tested the car today and it drives fine and everything, but the turbo dont spool up anymore it's behaving like non turbo now now.
there is no fault codes with the diagnosis
anbody have any suggestions what it could be?
changed turbo from ct26 to ct20b
changed turbo hotpipe
tested the wastegate is not stuck and goes back and forth
checked that there is noe loseness in turbo
and checked that there is noe leakage between turbo and intake
can anyone suggest further thing to investigate?
