Al-sw20 wrote:BKR7E NGK plugs.0.8mm
Rob - East Coast Imports wrote:I run NGK BCR8ES gapped at.8mm, it's worth noting if you're buying iridium tipped plugs
(I refuse to use them, btw) that they should never be cleaned or gapped at home.
JD wrote:Rob - East Coast Imports wrote:I run NGK BCR8ES gapped at.8mm, it's worth noting if you're buying iridium tipped plugs
I had no idea
I run 0.7mm so didn't re-gap them anyway, but I was remiss enough to not even think about that
cosmos wrote:My Denso ik22 are getting old now and if the tip lets go its wham bam according to a recent head damage post
copper is a better conductor than iridium or platinum, the only advantage of the fancy plugs is their service interval..
copper plugs are a couple of quid each, no harm in replacing them once a year
Race Idiot wrote:I wouldnt call them fancy plugs tbh just more modern tech, you do know the oem plugs for a rev3 turbo are platinums.
Gullzter wrote:Where are people getting their copper bkr7e plugs now
