I'm looking for a few bits of advice.
1.
2.
3.
4.
Thanks in advanced for your knowledge and help!
ghosty999 wrote:Hi all, new to the forum and the MR2 mk2 rev 5.
1.Where can I locate a new gator and gear knob? Will an E-bay MR2 knob and a gator from a Miata work?
2.Any advice on replacing speakers all round? They are all shot in the MR2 I've bought.
What size and is it just a copper wire soldering job?
3.Getting a rhythmic screaming noise coming that takes 10 seconds to fade out.
Coming from what I think is the power steering.
I've heard this is a common fault?
4.Really sticky 1st gear, basically if I want to drop from 3rd to first whilst rolling its near impossible.
jimGTS wrote:ghosty999 wrote:Hi all, new to the forum and the MR2 mk2 rev 5.
1.why from a miata? why not just get something made for the mr2?
2.depends on what sort of speakers you want, whether you want crossovers, an amp, subs and things.
most people make some 6.5inch spacers and fit those up front.
3.where is the sound coming from?
4.try and rev match instead of trying to force the gear when rolling, should slip in no problem then.
5.
welcome!
tiff_lee wrote:3.![]()
You get this when first turning ignition on and after alot of steering/coming to a stop?
tiff_lee wrote:That's what happens on mine, power steering pump but i've not got round to removing it and inspecting the state of the motor as mine sounds like knackered bushes/bearings.
What's the power steering fluid level like?
ghosty999 wrote:4.I'm guessing these are cable gear boxes? I never had a problem with them before like this, basically it wont go into first if I'm dropping to first from say 3rd.
I'll try rev matching but the gear box just seems very stick
(it is the original one)
Nic wrote:ghosty999 wrote:4.I'm guessing these are cable gear boxes? I never had a problem with them before like this, basically it wont go into first if I'm dropping to first from say 3rd.
It could be the gear linkage bushes are worn http://www.mr2oc.co.uk/know-your-2-know ... bartid=117
Also check the gear lever assembly, mine came with a poor quality short shift kit fitted which made gear changes very notchy.I've since swapped back to the stock which has made gear changes loads better.
ghosty999 wrote:Thanks for all the advice, had another go in it today, the power steering makes noises at the front near the pump and then the horrible noise stars usually when doing full lock to get out of parking spaces.
The stick gear issue I've tried to narrow down.Basically if I'm rolling at 20 towards a set of lights I can knock it into 2nd no problem but it's impossible to move it into 1st, it's like I'm locked out of that gear.
So I took it up a quiet road and tried to force it into first rolling with clutch down fully and just got the horrible gear box grinding noise.
Very odd!
