Auxiliary and Timing Belt Change
Nic
Post by Nic »
95 Rev3 Turbo
One of the auxiliary belts is squealing at start up, so I'm going to replace them and the timing belt. This is the list of parts I've got so far, is there anything else I'll need or any other parts you would replace whilst doing the belts?
13568-79105 BELT, TIMING
99364-80880 BELT, V (COOLER COMPRESSOR TO CRANKSHAFT PULLEY), NO.1
99364-80830 BELT, V(FOR FAN & ALTERNATOR)
13505-88480 IDLER SUB-ASSY, TIMING BELT, NO.1
13503-63011 IDLER SUB-ASSY, TIMING BELT, NO.2
13540-88480 TENSIONER ASSY, CHAIN, NO.1
Nic
[email protected]
MR2 Rev 3 GT Turbo
DB Mr2
Re: Auxiliary and Timing Belt Change
Post by DB Mr2 »
Water pump if it has not been done before Nic?
I've read lots of times on this forum and others that oil pump is not necessary..... But could always be done as a precautionary measure.
