[Mk2] [Turbo] Oil Pressure Gauge Brass Adapter?!
Which brass adapter with a braided line can I use to tap into the stock pressure sensor?
Re: [Mk2] [Turbo] Oil Pressure Gauge Brass Adapter?!
TheCombover wrote:Which brass adapter with a braided line can I use to tap into the stock pressure sensor?
If you let me know what you are trying to do I can sort out Goodridge hose and fittings for you.
