overheating
simpson_eh
overheating
Post by simpson_eh »
editing for a reason
Nails
Re: overheating
Post by Nails »
From what I've seen on here its a possibility your block is cracked.
Are you losing any coolant?
simpson_eh
Re: overheating
only through the overflow and its a 5sgte
mr2magic
Re: overheating
Post by mr2magic »
Possibly headgasket blown.
Btw: You shouldn't lose coolant through the expansion tank! Coolant that is forced into the tank by too much pressure is sucked back into the system when pressure is back to atmospheric.
Can you get the coolant CO tested to see if any exhaust gasses are present?
simpson_eh
Re: overheating
its back in the garage now so he can check i hope its not the block as that would be bloody costly being a 5s
bobhatton
Re: overheating
Post by bobhatton »
That is a sign of a cracked block.
If the compression ratio is too high for the fuel and boost being used the tuners just back off the timing to stop knock. What this does as well as losing a lot of power it brings the max cylinder pressure down into the bore where it is not designed to be and it is this pressure that cracks the block.
Re: overheating
bobhatton wrote:That is a sign of a cracked block.
Exactly the same symptoms I had last year. Off boost/flat roads, car was perfectly fine. Acceleration/up hill/on boost.....Temp went into the red. :(
Cracked block. Head off, piston number 1 had been steam cleaned by combustion pressure/coolant!
mr2magic
Re: overheating
Post by mr2magic »
^This! This is one of the root causes for lots of cracked blocks with higher power builds - nevermind wall thickness or overheating, i'm certain that 85-90% of the time it's the tuner/owner retarding timing to far on knock.
simpson_eh
Re: overheating
:( hope not as it was mapped by ryan who put it on the safe side whilst waiting to install another fuel pump and cams
it is running a 1.65mm headgasket on 8.5.1 pistons so shouldnt have cracked the block and only running 12psi of boost
MR2 Turbo Boy
Re: overheating
Post by MR2 Turbo Boy »
Ive the same with mine... 5S-GTE.. :-k
bobhatton
Re: overheating
Post by bobhatton »
simpson_eh wrote::( hope not as it was mapped by ryan who put it on the safe side whilst waiting to install another fuel pump and cams
Mapping on the safe side may well mean not having much timing advance.
The piston to head clearance should be no greater than 1mm.
Any larger will give an amount of charge that will burn very fast and give lots of knock.
If your pistons only come to the top of the block you now have an area of 0.65 to hold charge making the engine very prone to knock.
The correct way to design an engine is with the correct piston to head clearance and the pistons made with the correct compression ratio for the fuel and boost that will be used.
Fitting a thicker head gasket to lower the compression ratio may well end up giving greater problems, it is the wrong thing to do.
simpson_eh
Re: overheating
The head was skimmed so hence the bigger gasket
Odin_S
Re: overheating
Post by Odin_S »
I thought the 5 block was indestructible hence why ppl go for it.
This is the first I've heard
Adam86
Premium Member
Re: overheating
Post by Adam86 »
My car has this exact same issue. Head is now off and the head gasket has not failed but the block looks fine. The head is now being sent for pressure testing.
In people's experience is a cracked block usually visible to the eye?
Re: overheating
Adam86 wrote:My car has this exact same issue. Head is now off and the head gasket has not failed but the block looks fine. The head is now being sent for pressure testing.
Could simply be a hairline crack. Needs crack testing by a machine shop.
Adam86
Premium Member
Re: overheating
Post by Adam86 »
I really hope the head fails the pressure test.
