which one better
Tomas_St
which one better
Post by Tomas_St »
ct20b turbo or caldina turbo. is it possible to bolt on it on mr2 engine ???
2mad
Re: which one better
Post by 2mad »
From what i understand there the same turbo .. one can be bolted and unbolted from the stock mr2 manifold .. the other is a turbo and manifold in one (not sure if it fits rev3 +).. i would pick the ct20b (and did) .
rgb
Post by rgb »
id say yes cause iv got the new block with a ct 26 hybrid so it should work the other way .don't quote me.
kirk
Post by kirk »
As stated they're the same turbo except the Caldina turbo is part of the manifold casting. The manifold bolt pattern is different so won't fit a previous generations AFAIK
The CT20b may be an old turbo, but it's still great little turbo imo.
Al-sw20
Post by Al-sw20 »
You can't bolt the Caldina turbo and manifold (because it is one unit) onto a gen2 3sgte. Use the ct20b.
