Need some help please, I've lost one of the threaded bush for the headlights (the part that fits into the hole circled).
I have Rogue headlights fitted, not sure if the threaded bush is a stock OE part or part of the Rogue headlight kit?
Does anyone have one going spare?
Ordered a new OE bush from Toyota and it's different to the one I've lost, so I'm thinking it must be part of the Rogue headlight kit. I've tried contacting them but not had an answer yet.
If anyone has a spare one or may know where I can find one I'd be very grateful.
Cant tell from the pick what the rogue one might look like. But would it be possible to use a rivnut? You can even get rubber mounted rivnuts (see carbuildersolutions)
IIRC, the "shaft bit" (behind the thread) is little longer and sits in the oem location
It has 2 little nibs to stop it rotating once assembled
Heres a pic from the net...
Your best bet is emailing or calling Rogue to get a spare
