Ive recently bought a Power FC AP Engineering ecu.
I know this ecu has been modded by AP from its original counterpart to work with AFM Rev 2 MR2s.
I own an early gen2 jdm ecu P/N 89661-17320
Could anyone confirm me if im using the right ecu pinouts?
As far as ive read, this ecu can operate with AFM and also in speed/density mode.
o Option 1.
o Option 2.
Is there an aftermarket AIT sensor kit available?
Do you know if someone sells a wiring harness patch to do this required repinning with? I wouldnt like to touch my original harness.
Im still searching and reading a lot about the way this set up should work.
Thanks!
