I'll post the spec before the pictures actually.
Engine
Rev 2 turbo engine on just over 100k
Ct20b turbo
Rebuilt at 90k miles
Triple layered head gasket
New water pump
New dizzy cap
New rotor arm
Colder rated spark plugs
TRD leads
HKS FCON ECU
HKS fuel cut defender
HKS dump valve
Berk intercooler
Blitz manual engine lid fan
HKS turbo timer
Blitz dual Electronic boost controller.
Aluminium radiator.
Berk downpipe
Modified Japspeed decat exhaust
Polyflex engine mounts
Aftermarket catch can
ATF transmission fluid just put in
Chassis
Drilled and grooved front disks
Spax 40mm lowering springs
Front and rear strut braces
Exterior
Border rear spats
Bomex side skirts
Lenzo D1R Wheels
Resprayed in super red with black roof
Greddy splitter
Interior
Momo black leather wheel
Pioneer double din touch screen, Bluetooth, USB, aux in head unit.
Depo boost gauge.
The bay is very red and not to my liking but it's had far too much done for me to warrant reversing it all.
After that I got offered a wheel swap with a mate that would suit the 2 better than its current chavvy shoes so I went ahead with it.
At this point I had driven it for a while and had been toying with the idea of getting rid of it because of the horrible turbo performance.
I bought a ct20b off Sheppy from here
The turbo arrived and the task of changing it had to begin.
Ct20b arrival, looking dirty but no abnormal play, no oil, perfect.
Ct26 out
Ct20 in.
I started looking for a standard side vent set so I could remove the skirts and spats but I hadn't had any luck for a while.
Then still to no avail with the side vent, I got bored and decided to become an antisocial teenager.
I managed to setup some rota fighters in bronze, 17x8 fronts, 17x9 rears.
This is where I am at now, I'm not happy with the look of it just yet but it's getting there.
The car drives lovely though, since I bought it I had a few teething problems with boost hoses splitting due to being too close to the raw heat of the exhaust manifold
When I fitted the ct20 I didn't realise until half way through that the manifold wasn't standard and that it made the turbo mount slightly off the correct position so the support bracket on the bottom didn't fit so I had to leave it off.
I will update this as much as possible when I make progress, thank you for taking the time to look at my thread, any constructive criticism welcomed and any other comments appreciated.
Dan.
