[Mk2] [Turbo] Fit Rev5 NA UK Clocks into my Rev2 Turbo
Modena-360
Post by Modena-360 »
Having taken the hint to fit a boost gauge, I have seen a set of clocks on eBay item number:281672212271
However they are for a Rev5 NA. Can I fit these to my Rev2 Turbo? The goal would be to work on them off the car, fit an aftermarket boost gauge in place of the voltmeter then just swap them over. I want proper UK dials rather than a converter or a stick on face from Lockwood.
Will the Rev5 NA clocks even fit a Rev2 Turbo??
thomp1983
Re: [Mk2] [Turbo] Fit Rev5 NA UK Clocks into my Rev2 Turbo
Post by thomp1983 »
The simplest way is to take the 4 units out of the rev5 clocks and fit them to your rev2 unit that way there's no wiring to change.
Pauln
Post by Pauln »
Plus 1 :thumleft:
With the obvious exception of the voltmeter you can take all the gauges out of the na cluster and fit them in a turbo cluster. It's also possible to fit the voltmeter in place of the stock boost gauge in a turbo cluster, but this does require a minor mod the the cluster itself.
What you can't do is simply fit an na cluster in a turbo. The warning lights and wiring aren't compatible.
Paul
Modena-360
Really appreciate the help guys.
