speed sensor wire
speed sensor wire
Post by Martin F »
It has been a while :oops: , i have two wires to choose from for connecting the speed convertor behind the dash, one is purple with spots, the other is purple with a solid white line running down it.
Which one do i connect to the speed convertor on a rev 3 turbo, thanks :thumleft:
P.S. i spent 20-30 minutes searching but either i don't know how to use the search function properly or it's not very good...
MartinF
Re: speed sensor wire
Post by MartinF »
Probably a bit late, but the below should help.
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
Post by Martin F »
MartinF wrote:Probably a bit late, but the below should help.
Image Replaced With URL For Quote http://www.mkivsupraownersclub.com/imag ... ircuit.jpg
Thanks Dude, think it is the purple with silver dashes i was after, In the end i just fitted a steff derner delimiter, saved me cutting into the wrong wire :wink:
