Whats been changed is:-
Changing out rev2 loom and sensors ecu injectors for all rev 3
cometic head gasket, ARP bolts, full rebuilt on the head
all belts, bearings
drive-shaft seals, sump pan replaced.
New downpipe
engine oil been used is mobile one full syth, gearbox oil Redline MT-90
probs going to change the clutch also
Only thing i've purchased so far that i have not been to happy with was the finish on the berk down pipe, well its was shocking.
guessing this is called the
but on a lighter note blocks out time to get cleaning
only one thing I have been struggling to find is drain and filler plugs for gear box.
