Wind noise through tweeters
wenguin
Post by wenguin »
Hi folks
I've always had wind noise through tweeters and I've tried twice to apply double sided tape around the edge and refitting the mirrors with new screws, but the noise is, if anything, worse.
Was wondering if anyone had any suggestions other than replacing the rubber trim.
I've read that some people believe the wind can come through the 'gap' in the outside of the mirror, and into the inside of the mirror.
I've been thinking if I can get some sort of expanding foam into the part behind the tweeter it will block all gaps, but it would need to be removable - any suggestions for something easy to get out?
pistol pete
Re: Wind noise through tweeters
Post by pistol pete »
sounds silly Q
are you sure the noise isn't from the tweeter itself..
do you run an amp in you system?
super
Post by super »
Hi,
Have you ready this?
http://www.formesyn.com/mr2t/mr2Tprobsa ... .html#wind
Might help.
John
wenguin
Post by wenguin »
pistol pete wrote:sounds silly Q
Yes, it is wind noise.
Hi,
Might help.
John
Hi John, yes I tried this same thing mentioned on there, including attempting to tape around the screw holes. No dice sadly :(
madbasshunter
Post by madbasshunter »
I have sound deadening behind my tweeters
RyanRs wrote:
Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously , you don't know the answer to this? and you call yourself a car mechanic :shock:
androo007
Post by androo007 »
velcro down the sides works for a while - until it comes unstuck.
Its annoying me enough im considoring paying up the £50 for repplacment mirror holders
Ginjaninja92
Post by Ginjaninja92 »
I know you said it needs to be removable so this might not suit, but packing it full of silicon is the best method I've seen.
