Gaskets for intake/throttle body
JD
Post by JD »
When I get round to putting my intake back together, I'll be needing fresh gaskets. By my reckoning it'll be these part numbers. Can anyone confirm?
17177-88460
22215-74380
22271-88480
Peter Gidden
Re: Gaskets for intake/throttle body
Post by Peter Gidden »
JD wrote:17177-88460
Is exhaust manifold gasket for Rev3+ N/A.
Exhaust manifold gasket for 3S-GTE Rev3+ is 17177-88480. (IIRC, may be superseded to 88580)
JD wrote:22215-74380
Is ISC-to-TB gasket for all 3S engines except BEAMS.
JD wrote:22271-88480
Is TB-to-inlet manifold gasket for 3S-GTE Rev3+
JD
Post by JD »
Ah - I was going blind on what I could glean from ToyoDIY - looks like I was waaaay out 8-[
Thanks Peter. What's the full set I'll need for refitting intake manifold, throttle body and ISCV?
Peter Gidden
JD wrote:Ah - I was going blind on what I could glean from ToyoDIY - looks like I was waaaay out 8-[
22215-74380 ISC-to-TB
22271-88480 TB-to-Inlet Manifold
17177-88460 Cylinder Head to Inlet Manifold
JD
Post by JD »
Thanks, much appreciated.
