[Mk2] [Turbo] Where should this go?
TheDockter
Post by TheDockter »
so just put a rev2 engine in a rev1 shell... Cant for the life of me remember where this screws into.... Can anyone help? Thanks
Pauln
Re: [Mk2] [Turbo] Where should this go?
Post by Pauln »
As the shell is rev 1 I did wonder if that was from the cable driven speedo in the dash cluster, but I'd always assumed that would have a square end??
Paul
thomp1983
Post by thomp1983 »
Another vote speedo drive it goes on the top rear of gearbox
TheDockter
Ahh yeh... Does seem like it is the speedo cable now you say! Oh well one less thing to do :-)
Peter Gidden
Post by Peter Gidden »
If you've fitted a Rev2 gearbox, you'll need to fit the Rev1 cable speedo drive adaptor in lieu of the electronic one.
TheDockter
I didnt know there was an adapter! Do you have a link to one peter? :-)
Peter Gidden
TheDockter wrote:I didnt know there was an adapter! Do you have a link to one peter? :-)
Every gearbox has an adaptor to work the speedometer. You'll find it at the back of the gearbox.
Rev1 has cable drive, Rev2-5 has electric.
thomp1983
Post by thomp1983 »
On the back of your original gearbox the part that cable fits into is removable from the gearbox, remove it carefully and fit it in place of the electronic sender fitted to the gearbox now in your car
