EBC vs MBC?
MBC, get out the car, have a little fiddle, get back in the car, see if it boost where you want, if not, get out the car, have a fiddle, get back in, etc etc etc.
EBC, plug it in.
Foot down, if its not boosting right, twiddle a knob from the comfort of your drivers seat and change the boost.
On the GReddy you can change the gain and the set gain,
(spool up and consistency).
Built in digital boost gauge, warning settings, Variable boost limits.
Low and hi boost settings, ie mine is 15psi on the lo setting, and when I fancy, click
'hi' and it runs 17/18psi.
Great for when you bump into boxter S's!
and a bit of bling in the cockpit!
I'd definately pick an EBC over an MBC, there's just so much more to them.
Also, on the greddy, you put your foot down, turbo comes on, then when you slow down, the bc flashes the highest boost it just hit, so its great for monitoring whats going on.
