After careful consideration, myself and a couple of friends decided to go ahead and rebuild the engine
Whilst I have dabbled in breaks, servicing and general maintenance without problem, this was a reasonable challenge for me
Fortunately my mother has moved to an old farm house, and let me borrow a barn to carry out the rebuild.
It was pretty dirty below where the chargecooler sat:
I got quite excited when we removed the head!
Bottom end, caps marked ready for removal:
I couldn't really get a decent photo, however the cylinder had a small area where the piston/rings had caught:
Then the damage become obvious!
I thought this would be a good time to get the chargecooler and cam cover the once over:
Also cleaned the valves:
I had a local specialist look at the bore who advised honing, which was promptly carried out
New piston and rings arrived:
Big end shells replaced:
Jess the dog.
Done!
I've since sorted out the SW20 logo to reflect off the shroud
I also have several videos showing the first running, timing adjustment etc however these are appearing blank when uploading so I will sort these later.
Since the rebuild all has been working fine
Rob
