My s6 controls boost and I'm wanting to lower the boost in these winter months. Can anybody point me in the right direction please?
Cheers Dan
Syvecs s6 Boost control help
Re: Syvecs s6 Boost control help
Wrong section can somebody move to mr2 mk2 cheers
Gee Man wrote:Wrong section can somebody move to mr2 mk2 cheers
Done matey!
juliankv73 wrote:Gee Man wrote:Wrong section can somebody move to mr2 mk2 cheers
Done matey!
Wow that was quick!
Cheers mate !
If you don't get an answer from here SamBorgman at TDI is very hand with Syvecs ecus
Or Ryan from 2bartunning
Do you have multiple maps on the ECU? I know that when Ryan mapped my Syvecs, he left me with a map @ 1, 1.2, 1.5 and 1.7 bar (and also one at 1.7 bar with TC off).
Controlled by the rotary switch or the SCal software (or Toucan if you have deep pockets...)
January 2014
May 2015
Still in the garage...
..the only thing I can promise for sure is slow progress.
May 2015
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.
Shmed wrote:Do you have multiple maps on the ECU? I know that when Ryan mapped my Syvecs, he left me with a map @ 1, 1.2, 1.5 and 1.7 bar (and also one at 1.7 bar with TC off).
Yeh i've looked at the toucan! Like you mentioned NOT CHEAP!
I'm not sure if it has multiple maps, i'll have to plug the laptop in and have a look around as i've not got a rotary switch. I wasnt sure if i could just go in and lower the boost? Or if it will need checking fuel etc?
I'm sure you could go in and lower the boost, but in my (very black & white) mind, if you lower the boost, then the mixture will go richer. Better than leaner, but I'd always prefer to have the map checked at different levels of boost.
January 2014
May 2015
May 2015
