androo007 wrote:Hi Peter
What's the advantage over a stock rev 3 turbo ecu?
hkwc104 wrote:Potentially interested as I'm having my car done at Peter's(including the fitting of a chargecooler) but the reliability issue is a bit of a concern so would be interested to hear Peter's thoughts on this.
shinny wrote:hkwc104 wrote:Potentially interested as I'm having my car done at Peter's(including the fitting of a chargecooler) but the reliability issue is a bit of a concern so would be interested to hear Peter's thoughts on this.
Reliability issue? There's no reliability issue if you're controlling a GT4 chargecooler pump.In fact it gives you added protection as well as improved fuelling maps.
The issue only exists if you're trying to run the ECU on a car within a chargecooler.
hkwc104 wrote:Could you(or someone) clarify whether there might be any issues if the pump being used isn't the standard GT4 pump i.e.
a Bosch one?
