how can i stop the car from twitching when i hit redline
QUOC2008
Post by QUOC2008 »
how can i stop the car from twitching when i hit redline...?
Im running 450bhp witn a 2 way lsd and the car twitches everytime i hit redline the rear just wiggles asoon as the rev limiter comes in.
MR2 REV 3 TURBO 450BHP
3000GT VR4 TT 500BHP
EVO X FQ360
rev3turbo
Re: how can i stop the car from twitching when i hit redline
Post by rev3turbo »
dont hit the limiter? :-s
Draven
Post by Draven »
Don't red line it. #-o
bobhatton
Post by bobhatton »
Reprogram the ECU to give you another 1000 rpm before the rev limiter.
Ryan S
Post by Ryan S »
bobhatton wrote:Reprogram the ECU to give you another 1000 rpm before the rev limiter.
this is actually something you could do yourself I suspect, I've only used the G4 software a couple of times and I could figure out how to do that :thumleft:
QUOC2008
Post by QUOC2008 »
Its not easy all the time to perfectly shift without hitting the limiter... whats this g4 software? How do you mapp it out? And rising the limiter i would love to do but would there be any problems after :$ car forged etc etc...
Im still learning how to drive this devil of a car that so unforgiving
EVO X FQ360
SonicSW20
Post by SonicSW20 »
Do you have a dyno chart? You might not even need to go all the way round to the limiter (or just before) to get the most out of it.
QUOC2008
Post by QUOC2008 »
EVO X FQ360
SonicSW20
Post by SonicSW20 »
Looking at that graph, you don't need to rev it all the way to the red line - changing at around 7k should result in max acceleration as your power starts to drop off a little there, and you'll still be dropping it in that nice flat bit of the torque curve.
raptor95GTS
Post by raptor95GTS »
yeah defo try changing before 7krpm, no need to rev further than that since you're not making any more power up there.
Ryan S
Post by Ryan S »
QUOC2008 wrote:Its not easy all the time to perfectly shift without hitting the limiter... whats this g4 software? How do you mapp it out? And rising the limiter i would love to do but would there be any problems after :$ car forged etc etc...
it's the software used for mapping the link g4 ecu. you;d need to find out what software your ecu uses depending on what ecu you have :thumleft:
as already pointed out you could shift gear earlier though.
shinny
Post by shinny »
QUOC2008 wrote:how can i stop the car from twitching when i hit redline...?
Of course it does!! You're going from 450bhp to zero in a split second, so I'd expect the LSD to lock up and the car to squirm #-o
As others have said, either learn to drive better or increase your rev limit :wink:
QUOC2008
Post by QUOC2008 »
Thanks for the help guys... i gonna think about it.
Changing early is easy said then done when it hits full boost from 4000rpm you 0.10s of a seconds to change in 1st and 2nd gear im not that fast on changing gears if you guys know a special way let me know... lol
Right now im just comfortable in the spooling of the turbo power band otherwise things get a bit twitchy
EVO X FQ360
Odin_S
Post by Odin_S »
Change back to standard LSD, i see no reason for a 2 way on a road car
QUOC2008
Post by QUOC2008 »
Odin_S wrote:Change back to standard LSD, i see no reason for a 2 way on a road car
I was thinking this would fix the issue... 1.5way lsd which is standard. I think this lsd can be adjusted to 1.5 way
EVO X FQ360
Rev5GT
Post by Rev5GT »
QUOC2008 wrote: hits full boost from 4000rpm you 0.10s of a seconds to change in 1st and 2nd gear
I want a passenger ride in your car :mrgreen: :thumleft:
Draven
Post by Draven »
That does sound insane
nathan.z
Post by nathan.z »
QUOC2008 wrote:Thanks for the help guys... i gonna think about it.
Sequential gearbox? :whistle:
QUOC2008
Post by QUOC2008 »
I guess some people are that good superman but im not superman ... free rides yeah no problems but i cant guarrante ur safety
EVO X FQ360
QUOC2008
Post by QUOC2008 »
Anytime rev5GT in london
EVO X FQ360
