Valve stem seals, mk2 turbo
Ryan S
Post by Ryan S »
can somebody tell me the correct part number for these? Cheers,
Ryan.
DB Mr2
Re: Valve stem seals, mk2 turbo
Post by DB Mr2 »
Hi Sheppy,
Sorry to jump in on this but I would also be very appreciative of part numbers.
I assume they are the same for rev1-5 turbo heads.
Thanks,
Dan
Nic
Post by Nic »
sheppy wrote:can somebody tell me the correct part number for these? Cheers,
Ryan.
Are you buying a full engine gasket/seal kit for the rebuild? if so the valve stem seals are included in the kit.
These are for the Rev3+ 3SGTE
Nic
[email protected]
MR2 Rev 3 GT Turbo
Ryan S
Post by Ryan S »
DB Mr2 wrote:Hi Sheppy,
Thanks,
Dan
no problem man, I'm not sure if they would be, the heads are different on rev1/2. rev3-5 would be the same though.
Ryan S
Post by Ryan S »
Ryan.
Image Replaced With URL For Quote http://i59.tinypic.com/2wnzne0.jpg
I'm not no, I already have a gasket set but no valve stem seals. Don't think it was a full gasket set, just turbo/manifold etc....
Ryan S
Post by Ryan S »
£117 plus VAT from Toyota :shock: :shock:
Nic
Post by Nic »
sheppy wrote:£117 plus VAT from Toyota :shock: :shock:
If you still need a head gasket it might be more cost effective to buy a complete valve grid kit, this includes everything for a cylinder head rebuild.
Nic
[email protected]
MR2 Rev 3 GT Turbo
Ryan S
Post by Ryan S »
Image Replaced With URL For Quote http://i61.tinypic.com/2hyxy4y.jpg
Cheers for that Nic, I do need a head gasket. Will try a few other places too, Hurley Engineering seem to do Toyota parts at amazing prices, unfortunately no valve stem seals though :(
2mad
Post by 2mad »
Could just phone your local Toyota parts department .. mines well helpful .. got all the right parts so far 8-[
Ryan S
Post by Ryan S »
2mad wrote:Could just phone your local Toyota parts department .. mines well helpful .. got all the right parts so far 8-[
I did, £117.50 plus VAT!!!
My mistake, Hurley do have them (although searching their shop nothing came up)
http://www.ebay.co.uk/itm/Supertech-Per ... 3f44ca556e
Fits all revisions :thumleft:
Purchased :)
Nic
Post by Nic »
Personally I've only ever used genuine OEM Toyota gaskets/seals for my engine rebuilds as you know the quality.
Try getting a quote from Steve Manley ([email protected]), I always use him as he gives me the best prices, tell him Nic with the MR2 recommended him.
Nic
[email protected]
MR2 Rev 3 GT Turbo
Ryan S
Post by Ryan S »
Nic wrote:Personally I've only ever used genuine OEM Toyota gaskets/seals for my engine rebuilds as you know the quality.
Na, Hurley only use good parts, according to reviews etc these can handle higher temps than OEM and take more "abuse". :thumleft:
2mad
Post by 2mad »
Holy cr*p .. thats the price .. ouch mate ](*,)
DB Mr2
Post by DB Mr2 »
Cheers Nic, that's great.
So it looks like I will buying a full engine gasket set for rev2 turbo (for valve stem seals and manifolds etc.) and then having to purchase the upgraded rev3 steel head gasket separately.
Which leaves me with a rev2 headgakset not being used - oh well from researching it seems the rev3 gasket is much better than the rev2?
Cheers again gents,
Dan
Ryan S
Post by Ryan S »
Yeah bonkers!!
The VAT is £23.50! or £26.50 for supertech ones :)
kev8611
Post by kev8611 »
I have supertechs. Been ok so far and alot cheaper lol
Ryan S
Post by Ryan S »
kev8611 wrote:I have supertechs. Been ok so far and alot cheaper lol
talking to a friend about them tonight, considered an upgrade over OEM by many people :thumleft:
Nic
Post by Nic »
How are they are an upgrades over OEM? They are a cheaper aftermarket alternative. If I was going to the expense of building an engine I would only use OEM Toyota. Aftermarket is really not always better.
Nic
[email protected]
MR2 Rev 3 GT Turbo
Ryan S
Post by Ryan S »
As above :thumleft:
Just because something's OEM doesn't mean it's better than a cheaper alternative.
Peter Gidden
Post by Peter Gidden »
DB Mr2 wrote:So it looks like I will buying a full engine gasket set for rev2 turbo (for valve stem seals and manifolds etc.) and then having to purchase the upgraded rev3 steel head gasket separately.
Dan
Exactly the way we do it.
DB Mr2 wrote:from researching it seems the rev3 gasket is much better than the rev2?
Rev1/2 is fibre. Rev3/5 is MLS.
