Has anyone set their car up
Sounds bonkers i know, but I guess its more wear and tear on the turbo
sheppy wrote:not quite as extreme as that but i have a setting on the controller that runs 3-4psi for when I let the missus use it, or if I need to leave it at a tyre place or whatever and know some wee idiot is gonna try and kick the crap out of it.I'd like to see the disappointment on their face
perfect example being letting some idiot fit skirts to it, he then proceeded to drive it to my work with no driving licence.i was fuming, buuuut he was subject to the limited boost so at least he didn't crash it.
pistol pete wrote:sheppy wrote:not quite as extreme as that but i have a setting on the controller that runs 3-4psi for when I let the missus use it, or if I need to leave it at a tyre place or whatever and know some wee idiot is gonna try and kick the crap out of it.I'd like to see the disappointment on their face
nobody drive mine except me or a chose few..
and my car never gets left anywhere for this to happen.
for this reason
jon wrote:I thought the minimum boost pressure was controlled by the wastegate actuator spring?It's not possible on a stock turbo to run less than 6 or 7psi if everything's working properly.
androo007 wrote:oh really, thats interesting, thanks guys.
6psi is a lot better than 12psi- so i can see a tangable good reason for having it there then
- definately agree with reducing for the garage.
Always some div who wants to give it some when you're not there.
simpson_eh wrote:i always bring the revlimit on the hand controller down to 3k then unplug the hand controller and take it with me
when it goes to garage lol
jimGTS wrote:but wont it be making full boost at idle?
sheppy wrote:perfect example being letting some idiot fit skirts to it, he then proceeded to drive it to my work with no driving licence.i was fuming, buuuut he was subject to the limited boost so at least he didn't crash it.
jimGTS wrote:jon wrote:I thought the minimum boost pressure was controlled by the wastegate actuator spring?It's not possible on a stock turbo to run less than 6 or 7psi if everything's working properly.
+1
min you can run is 7psi or 0.5bar
sure you can feather around 0-0.2bar or whatever, but foot down, hi-ish rpm you will reach 7psi.
Marf wrote:jimGTS wrote:jon wrote:I thought the minimum boost pressure was controlled by the wastegate actuator spring?It's not possible on a stock turbo to run less than 6 or 7psi if everything's working properly.
+1
Assuming you don't have a big exhaust.on my setup
(naughty naughty t.b.d downpipe, fujitsubo RM01a exhaust) under full throttle I saw 7psi until 5000 RPM or so, then it crept to 11psi.
