Rev 1 turbo speedo cluster into Rev 2
Sigster100
Post by Sigster100 »
Hi all. I need to put a new speedo cluster into my Rev 2 turbo. I have been offered a cluster from a Rev 1 turbo. Is it compatible with my car?
Pauln
Re: Rev 1 turbo speedo cluster into Rev 2
Post by Pauln »
I think you'll find the rev 1 has a mechanical drive for the speedo, where as rev 2 on uses an electronic speedo drive.
Easy to spot which is which if you take a look at the back of a rev 1 cluster you'll see the threaded sleeve poking out where the cable is attached for the mechanical drive.
Paul
Sigster100
Thanks Paul. Yep, spotted that. Search continues :)
thomp1983
Post by thomp1983 »
What's wrong with your current unit?
