wiring inside A pillar
drunknmunky
Post by drunknmunky »
Hi guys,
noticed after removing the A pillar trim that the thin black wire that runs up inside is snapped, can anyone tell me what it is for please?
shinny
Re: wiring inside A pillar
Post by shinny »
Hmmm - that could have been installed aftermarket for some form of aerial by a previous owner. Or it could be the wiring for the courtesy lights - check they work from the buttons and with the doors.
drunknmunky
its not the courtesy lights, they are still working off doors and switch.
shinny
Post by shinny »
drunknmunky wrote:its not the courtesy lights, they are still working off doors and switch.
Meh... there's no other stock wiring up that way AFAIK, unless you somehow have a RHD USDM chassis??
markstevieandmads
Post by markstevieandmads »
I'm guessing an aftermarket alarm sensor? If there isn't one then may have been pulled off when removing one?
As above, sounds like an aftermarket alarm sensor wire.
Torero
Post by Torero »
+2 :thumleft: mine was the same and it ended somewhere behind the firewall carpet.
3VZ-FE V6 TRD Widebody Replica
Draven wrote "TRD dude. TRD... Can see awesomness from anywhere. "
drunknmunky
Ok thanks people, I won't worry about it then :D
