Another place iv found water coming in!
STUAW11
Post by STUAW11 »
Iv recently resealed both quarter light windows as i heard these can leak, after a night of rain about a week ago there was water on the passenger floor again, after checking around the quarter window everything was dry...but did notice some water coming from a seam just down from the rear window close to the quarter window..i checked the drivers side and was coming in the same place, seems to be getting past the seam..is there a cavity behind this seam which goes to the back of the engine bay below the rear window? i should also mention that the car stands on my driveway which is on a downslope, iv been told i need to find the entry point of the water and seal that first..or i could just get as much of the old seam sealant out and redo it..anyone had this problem before?
87 T-Bar Manual Supercharger
98 T-Bar Rev5 Sonic Shadow
Rob
Re: Another place iv found water coming in!
Post by Rob »
My experience is that you've not sealed the windows properly. Sit in the door on the sill and use a shower head hose at the gutter point outside and check carefully.
aussieGT
Post by aussieGT »
could be worse, imagine it in vi or x places.
I guess it would really be a sieve if it leaked in mm places.
JD
Post by JD »
aussieGT wrote:could be worse, imagine it in vi or x places.
Lol, smartarse.
I'm gonna check mine. I wish OEM seals weren't such a ripoff.
STUAW11
Post by STUAW11 »
The water is definitely coming from the seam and not the quarter Windows as iv successfully resales them with no water ingress.... it's building up in the cavity behind this seam.pic1...how could water get into this cavity? I think the back of the engine bay under the rear window is the bottom skin of the cavity...I just don't know how it gets in :mad:
