Please help me!
Bumble-bee
Please help me!
Post by Bumble-bee »
Hi guys.... My Rev 2 3sgte turbo import is being a typical women... And still not putting out 😂 she won't start guys I'll gove you a list of what's been done and any help will be great ful as to what it could be :)
She cranks and cranks until she almost starts then then she Fires up but runs completely fine, no cutting out no misfire, boast 100% fine no noises nothing!
Had new gt leads dizzy cap rotor arm and a full service carried out,
Spark tested and its a really strong spark, so can't be coil
When she finally starts white smoke floods out the back so there is fuel in the engine once it starts! She has to rev a little to get rid of it but then idles fine afterwards
Had the gearbox and clutch changed so I thought maybe that the earthing wasn't right but my mechanic has checked all of these again and they are all on tight,
Had a new battery fitted to it and still having the problem just cranks and cranks and finally she starts again and I have to go on a bit of a d tour to charge the battery!
Any help to get her to fire up first time everytime!!! But now and again she fired up straight away and I want this problem to stop!
Please help guys im trying everything! This problem only started a few weeks ago and I had the car in September and it's been fine up until recently!
thomp1983
Re: Please help me!
Post by thomp1983 »
If your sure of the spark and no ones done anything that would affect either the static or dynamic timing then id be looking to do a compression test and check the fuel pressure
Nic
Re: Please help me!
Post by Nic »
Any ECU fault codes?
Nic
[email protected]
MR2 Rev 3 GT Turbo
Bumble-bee
Re: Please help me!
Nic wrote:Any ECU fault codes?
No light has come up so I haven't bothered trying it and she needs to be started to see them right?
Ryan S
Re: Please help me!
Post by Ryan S »
no, the light won't come on man, just turn on the igntion and bridge the terminals, get somebody to see what the EML does, if it flashes constant then there's no codes.
Bumble-bee
Re: Please help me!
So the engine doesn't have to be on just 2 clicks or shall I get her started?
thomp1983
Re: Please help me!
Post by thomp1983 »
Just on 2 clicks not started
Ryan S
Re: Please help me!
Post by Ryan S »
as above, 2 clicks and the EML will light up, It will flash as soon as you bridge the terminals so easiest with 2 people :thumleft:
Bumble-bee
Re: Please help me!
sheppy wrote:as above, 2 clicks and the EML will light up, It will flash as soon as you bridge the terminals so easiest with 2 people :thumleft:
can I bridge and then start? However if that reads as nothing wrong where do I go from there? Because this is really starting to make a love hate relationship but i was enjoying this car so much 😔
Ryan S
Re: Please help me!
Post by Ryan S »
no that doesn't work, it's really frustrating that it doesn't!!
what you could do is put a switch between 2 wires then bridge them. then you can just flick the switch.
Gullzter
Re: Please help me!
Post by Gullzter »
Turn ignition on but dont start engine as sheppy says, then put a clip or wire between the 2 terminals then go back to dash and read the codes, it will continuously repeat codes til terminals are unbridged or ignition switched off anyway
markstevieandmads
Re: Please help me!
Post by markstevieandmads »
Rev 2 turbo? Check the ecu for blown capacitors. Very common
2mad
Re: Please help me!
Post by 2mad »
markstevieandmads wrote:Rev 2 turbo? Check the ecu for blown capacitors. Very common
Yep .. mine leaked their electrolytes on to the bored :cry:
alanmr2turbo
Re: Please help me!
Post by alanmr2turbo »
Yes you can bridge and then turn key. Its how i do mine.
Ryan S
Re: Please help me!
Post by Ryan S »
ah, well that deffo doesn't work on mine, the EML just stays on :(
jimGTS
Re: Please help me!
Post by jimGTS »
yeh defo only 1 pair of hands required to check error codes.
bridge, key to ON position, job done.
Draven
Re: Please help me!
Post by Draven »
Yup i can bridge and then turn the key.
I would check the ECU see for leaky caps. I had this problem with mine. Replaced the ECU in the end and all was perfect. :thumleft:
Bumble-bee
Re: Please help me!
Draven wrote:Yup i can bridge and then turn the key.
Bridges and then turned the key worked perfectly fine and just a constant flash reading no codes :( could this still be an ecu problem and how much are they to get one?
To the other guy who asked its is a Rev 2 turbo :(
Draven
Re: Please help me!
Post by Draven »
Yes it could be an ECU problem. The big issue with bulging capacitors is that they slowly get worse so one day you'll wake up and the car won't start first time or maybe you'll get pops and bangs when you shouldn't eventually the car just won't start at all when they've leaked all over the board.
Well first things first.. open it up check the board you're looking at the capacitors see if any are bulged or even leaking. If you're good with electronics you can replace capacitors your self.
I got mine from someone on here who fixes them and sells them on (can't remember who). If it is indeed the ECU stick a wanted add up and then check the breaker section PM some of the guys on there.
I paid £70 and my old ECU as part ex. So expect to pay £100+ for one.
Draven
Re: Please help me!
Post by Draven »
The final time before mine wouldn't start I was driving down the road and it was coughing and spluttering shooting 3ft flames out the exhaust with lots of black smoke. :shock:
I thought that was game over.
Once I figured it out it was actually one of the more simpler issues i've had.
