calling BC coilover owners.
gerbil1028
Post by gerbil1028 »
Last owner has cabled tied the brake lines to coilovers, standard lines.
Looking online it says this should not be needed with BC coilovers
Any thoughts.
One day the Phoenix will rise from the ashes.
bobhatton
Re: calling BC coilover owners.
Post by bobhatton »
gerbil1028 wrote:Last owner has cabled tied the brake lines to coilovers, standard lines.
Any thoughts.
A photo or two will help to see what you have got and why it is not fitted the right way
gerbil1028
Won't get to car until later.
Just curious as most online info says there's mount points on coilovers for lines to bolt too
killerferret666
Post by killerferret666 »
there are mounting points off the coilover bottom brackets for brake lines to clip into.
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
gerbil1028
Will check it over properly later when at car. But previous owner seems to have cine above calipers then cable tied to coilovers and taken downwards to calipers
gerbil1028
Any pictures of correct routing and securing to check mine against ?
Gullzter
Post by Gullzter »
There should be a mounting point just above and 90degree to one side for it, your brake lines also need clips to secure it to the coilover
gerbil1028
So as last owner cable tied to coilover and I can't see anywhere am I just blind?
Have not looked that hard yet I admit. Winder if he just lost all the clips and cable tied instead ?
gerbil1028
Can't believe I am going to admit this.
All brackets are present And correct the cable tied wires I was looking at was the abs sensor wires.
Let the p1$$ take commence.
