daviefoster9773 wrote:Engine management came.on when I was giving the car a good going.I have a boost controller fitted, but aince management light comes on, it will boost to 10psi gradually even tho ita set at 7psi.
And 18-19 psi even tho ita set at 17psi
daviefoster9773 wrote:Engine management came on
daviefoster9773 wrote:I have a boost controller fitted, but aince management light comes on, it will boost to 10psi gradually even tho ita set at 7psi.And 18-19 psi even tho ita set at 17psi
Gullzter wrote:My knock sensor went and still did rev til red line.![]()
If you check error codes and knock sensor has went then yes it will happen again til you diagnose and fix issue.![]()
Error codes will hopefully tell us alot more![]()
RedMR² wrote:Gullzter wrote:My knock sensor went and still did rev til red line.![]()
Red lining the car while running in your new engine!?
Red lining the car with no knock sensor!?
Gullzter wrote:RedMR² wrote:Gullzter wrote:My knock sensor went and still did rev til red line.![]()
Ehhh who said the new engine?![]()
Wasn't it discovered your knock sensor had gone/error codes on dash when your new engine was installed?
Absolutely no idea where or who you got that from, but since you ask i found the knock sensor had went November last year
You're correct!
thread: http://www.imoc.co.uk/forums/viewtopic.php?t=175624
In that case, you've been driving around in the car for a year with error codes 21& 52, without buying new sensors.
Tight git!
daviefoster9773 wrote:And where do I get the restrictor rings?
Rob85 wrote:daviefoster9773 wrote:And where do I get the restrictor rings?
youdon't
want to fit a restrictor ring.
unless the only reason you fitted a new exhaust was because it's shiny and loud?
