Seen a few of you do it on here over the years, how's it done?? what products do you guys recommend? My car's looking pretty good but the rear lights are deffo gonna let it down
All advice welcome
cleaning up rear lights??
Re: cleaning up rear lights??
A mop and cutting polish is the easiest. If no mop you can use metal polish by hand.
- IMOC Moderator
Nails wrote:A mop and cutting polish is the easiest. If no mop you can use metal polish by hand.
think i'd prefer doing it by hand, I do MOP cars at my work and i'm good at it but i've never done this kind of plastic before, I actually need to go get some metal polish, just work it in leave to dry?? or work it in so much that it comes off??
I used t cut and autoglym on mine.
- IMOC Moderator
RedMR² wrote:I used t cut and autoglym on mine.
how did they come up?? Actually, I think I seen yours, they looked good, I have autoglym products coming out my ears at work, what autoglym stuff did you use?? I have a form of t-cut as well.
He should know - God, he's done enough of them!
- IMOC Moderator
Peter Gidden - SBITS wrote:RedMR² wrote:I used t cut and autoglym on mine.
I'll follow his advice then
I did the same - looked ace!
Depends on how bad they are. Just regular car polish works well, though you may need something a little more abrasive if they are really bad.
sheppy wrote:Peter Gidden - SBITS wrote:RedMR² wrote:I used t cut and autoglym on mine.
lol
T - cut, effort and autoglym super resin polish. Comes up like glass.
- IMOC Moderator
you know this, i've no idea how bad they are, i just remember seeing Craigs and assuming mine were rubbish, collecting the car at 5 so will get stuck in about the lights, i only use autoglym at my place (occasionally chep crap that the reps hand in). What autoglym product did you use Craig?
EDIT: never mind, I somehow missed your last post, that's good, i have loads of super resin
Best way is to sand them down, then re laquer and sand/polish up...
- IMOC Moderator
n52 wrote:Best way is to sand them down, then re laquer and sand/polish up...
hmmm, not keen on that idea, I do understand it'll get best results but i'd end up ruining my lights
Fine cut polish and fine cut pad + mop = finish with super resin polish
Thats how i would start , would go harder pad , harder cut polish if needed.
Rear Lights
How bout toothpaste for sensitive teeth!
Funny my Uncle told me to try this on my Jag front headlights, have not tested it out yet!
Dans Modified MR2 Turbo >>> http://www.imoc.co.uk/forums/garage.php ... e&CID=2727
Bit overkill for a bit of oxidisation.
D4N_V_U wrote:How bout toothpaste for sensitive teeth
If its toothpast with bicarbonate soda , could work
Toothpaste urban myth......tried it
Didn't think about metal polish though, felt bit too abrasive
I used tcut on my dads car and they came up a treat
