Toyota MR2 Revision 3 Turbo T-Bar Import 1994.
It has had a FULL engine rebuild by Simon at YVS Performance in Sherburn in Elmet around 2000 miles ago.
Finished in Steel Mist Grey SMG.
The service history for the car is phenomenal, there is receipts for 1000s and 1000s and every MOT is in the history file.
Full Engine List;
Good used 3S block on standard 86mm bore.
CP Carrillo Forged pistons at 86mm standard compression ratio.
Full Toyota gasket kit.
Full Toyota cambelt kit with Gates cambelt.
Toyota water pump and oil pump.
Head fully rebuilt.
Cam cover professionally powder coated in a nice silver colour.
Full Exedy clutch kit.
Crank checked and polished.
ARP bolts.
ACL Race bearings.
Low mileage CT20b Turbo.
Berk downpipe with Decat.
Run in on Millers 10w40 Running in oil.
Gulf Competition 10w40 Ester based Fully Synthetic oil.
Coolant changed.
Block fully cleaned and painted in black high temperature paint.
NGK spark plugs.
Toyota leads.
Modifications;
Apexi induction kit.
Mongoose stainless steel exhaust.
Fensport 1 bar Turbo actuator.
Side skirts.
17 wheels with correctly staggered tyres.
Aftermarket stereo.
Berk down pipe and Decat.
Tein Superstreet coilovers which cost over a grand with receipt to prove.
Bad Points;
There is a bit of bubbling on the passenger rear arch and the slightest bit on the drivers arch.
The idle can be slightly low at times but doesnt happen often but I want to be honest.
The door open light sometimes lights up when everything is closed.
Mileage is 128000 but the only thing original really is the shell.
Air con doesn't work.
The car is priced at
I will listen to offers when you have viewed the car but not before.
Viewing is recommended and can be arrange when convenient.
The car is located in TRURO, CORNWALL.
I have probably missed something but please feel free to PM me or ring me on 07881482167.
Thanks Rich
