OK,
answered my own question,
Here is the info for anyone else looking in the future:
So Eagle rods are worthwhile over stock if you're looking to lose some weight and rev harder
Piston/ Conrod Weight
OEM Rod/Piston Assembly inc bearing 1.4 kg
OEM Rod/Piston Assembly No bearing 1.35 kg
OEM Con Rod
With Nut/stud 0.8 kg
OEM Piston
- With Pin
+ rings
+ circlips 0.6125 kg
Eagle Rod Weight
(From Website,
includes ARP bolts) 0.555 kg
JE Piston Weight
(Just Piston no rings etc.
- From JE) 0.351 kg
JE piston with rings pin etc.
(From JE) 0.483 kg
Total Forged Weight 1.038 kg
Weight saving 0.312 kg
Weight saving
(Total Four Piston/Rods) 1.248 kg
Con-Rod Saving
Eagle vs Stock 0.245 kg
Piston Saving
JE Vs Stock 0.1295 kg
