So here it is guys.
MR2Factor Toyota MR2 AW11 Download
v0.91 Patch
- Just extract the GameData file and then drop it in your rFactor folder and overwrite when prompted.
AW11 v0.91 Patch Download
Version 0.9 Beta Release
includes:
MR2 Mk1b
(Standard)
- Toyota 4A-GE 1600cc I4 125bhp
- All standard factory colours, and some Mk1a colours too
(as there is no Mk1a model I've just painted the car to look like one.
MR2 Mk1.5
- Toyota 3S-GTE 2000cc I4 Turbo 300-400bhp
- Inspired by Woodsport
MR2 Mk1.6
- Toyota 2GR-FE 3000cc V6
(Yes the one from the Lotus Evora!) 300ish bhp
Track Attack Race Club MR2 Racing Series
- Based on the Standard Mk1.
Liveries from 2014
It now also includes:
Racing interiors for the race cars
6 different wheel options
Pop up headlights
Working lights
Working gauges
A huge rear spoiler for the boy racers amongst us.
Tin tops for the race series.
Talent files
RealFeel or standard FFB
Small Readme
"Start off with the standard 1.6 NA.
This car is relatively underpowered, 122bhp, so is hard to slide in the dry, just like the real thing it's fairly well planted.
Next try the MK1.6 V6.
This has a lot more power as it has the Lotus Evora engine conversion.
It's my personal favourite as the torque comes in very low down.
It's not the fastest but its easy to break traction and slide.
And it sounds awesome!
Then try the Turbo.
This is the fastest and scariest.
If you're brave, put the boost up to 10! It is a very hard car to drive.
The handling is pretty much the same on all cars.
You can stiffen the rear ARB on the more powerful cars if you're having trouble putting the power down.
Also the brakes can be quite tricky, especially on the faster cars.
Try adjusting the bias and pressure if you're locking up and spinning.
Try not to downshift too fast as you would in an F1 car as this will lock the rear wheels and you will spin.
Bring the speed down first on the brakes, then downshift.
Install this on a fresh install of rFactor.
Set your steering wheel settings to 360deg in your logitech controller profiler and also in your controller.ini.
And for gods sake use the realfeel FFB in the upgrades, its what this mod is designed for!!! Some people who have tried it have said the steering is much too responsive.
I don't know what's going on with that as it seems to work fine on a fresh install.
I need to find out if it's a mod, plugin, or steering wheel issue.
Enjoy!
