JD wrote:I need to tap the cold pipe for the water injection but the aluminium pipe I have is only 2mm thick.![]()
I know plenty would say keep it ally but I'll need a thicker one to tap because 2mm just isn't anywhere near enough thread so I would consider SS.
What are my options?
I could tap the IC just before the outlet I suppose
- would this be better?
JD wrote:My understanding was that it should be placed after the I/C to maximise the efficiency of the IC but as far back as this will allow from the throttle plate as possible to maximise atomisation/distribution in the intake charge.
I can see how individual nozzles in each branch would make sense.
It will be mapped for anyway.
2mad wrote:JD wrote:My understanding was that it should be placed after the I/C to maximise the efficiency of the IC but as far back as this will allow from the throttle plate as possible to maximise atomisation/distribution in the intake charge.
This^^ I placed mine here.
[url]http://i948.photobucket.com/albums/ad323/mr2turbobitz/Imoc/P21-06-12_2023-1.jpg
[/URL]
Worked great, had very low iat temps
Martin F wrote:2mad wrote:JD wrote:My understanding was that it should be placed after the I/C to maximise the efficiency of the IC but as far back as this will allow from the throttle plate as possible to maximise atomisation/distribution in the intake charge.
[/URL]
This is a good place to put it, if you put it in the inlet manifold the standard air temp does not pick up any of it's cooling effect and retards the ignition when it detects the higher temps side mount intercoolers inevitability put out at higher boost levels.
[/URL]
[/URL]
another good point
[/URL]
There is NO cooling of the inlet air with water injection
JD wrote:Here we are specifically talking about water/meth, rather than just water, and it should work to cool the pistons at least? Cooler pistons are stronger pistons? The main benefit is knock-retardation, surely, allowing for more aggressive ignition timing, yes?
Not arguing- just want to understand why we see lower IATs when injecting water then? Is the water"fooling" the sensor?
Nic wrote:Good post on the subject of WI here by Chris Wilson
http://www.mkivsupra.net/vbb/showthread ... ost1220993
To answer my own question: the IAT sensor is also reading the temperature of the water being injected, so the reading is no longer a pure inlet air temperature- it's an average of the air temperature(higher) and the water droplet temperature
(lower).
My interpretation anyway..
So..
.is water injection actually producing an inter-cooling effect at all?? If my explanation is correct, then no it is not.
Starting to understand Bob's prior comments on this now(I think)
