Recirculating valve from Rev2 or Rev3?
TrevorV
Post by TrevorV »
Is the any difference between the stock recirculating dump valve on a Rev2 and Rev3?
I've just installed a CT20b turbo on my Rev2. Either the stock recirc dump valve couldn't handle the additional boost pressure or it's faulty. The only way I could get the car to run was to remove it.
Do I replace the stock recirc dump valve form a Rev2 or does it have to be from a Rev3, now I have installed a CT20b turbo?
MR2 MK2 REV2 3.5V6 2GR-FE
jon
Re: Recirculating valve from Rev2 or Rev3?
Post by jon »
There's no difference between a Rev 2 and Rev 3 recirc dump valve, it's the same part no. 17670-88380 .
TrevorV
Post by TrevorV »
Thanks :D
