Boost problem.....advise please
jcurtis6183
Post by jcurtis6183 »
Hi guys,
My rev3 tubby has recently started to 'stutter' when reaching approx 0.80 on the gizmo boost controller (set to 1.20).
She runs smooth as ever until that part and still wants to keep pulling until the 'stutter' kicks in.
Any ideas??
Peter Gidden
Re: Boost problem.....advise please
Post by Peter Gidden »
Let's start with the obvious.
What's it like with the Gizmo removed?
Draven
Post by Draven »
Peter Gidden - SBITS wrote:Let's start with the obvious.
+1
remove the gizmo test the turbo if it runs fine boost controller fault.
Tomas_St
Post by Tomas_St »
was same problem... found damage hose :) simple problem
jcurtis6183
Any idea where I would run the vacuum hosing to rather than the gizmo? Sorry I've owned her without the boost controller so no clue to the original plumming #-o
jcurtis6183
Tomas_St wrote:was same problem... found damage hose :) simple problem
Ah my friend said the same so I swapped a whole load of stock hoses.....which one did you find an issue with?
Peter Gidden
From turbo compressor to actuator.
jcurtis6183
Ah I'm with you, will try on the weekend for sure.....away at work until then :(
Draven
Post by Draven »
I'd picture mine but it is a mess at the moment.
