So, as a result, i have for sale, a SPA Design Duel Digital Boost Pressure and Temperature 52mm Gauge.
This is BNIB, opened only to check contents, and was destined for my Noble later this year.
SPA Design should not be confused with any other gauges.
This dual gauge is one of the most accurate pressure and temperature monitoring devices available.
Features include:
Switchable colour backlight
Adjustable backlight brightness
User programmable settings for pressure and temp i.e.
High resolution modes for 0.1 PSI or C etc
Programmable button function, recall and menu etc
Industry standard sensors
Programmable warning lights, including low battery
Programmable outputs for driving external LEDs, buzzers, lamps or relays
Programmable high and low alarm settings for both pressure and temperatures
Contrast adjust for easier reading at different viewing angles
The temperature sensor is designed for measuring oil, water, fuel etc.
Price new
I'm asking
