raptor95GTS wrote:touch wood I fixed the drivers side leak using the silicon trick.I have a bead running across the tbar glass parallel to the roof seal and now it only drips slightly and only when driving in the rain, proof I suppose that tbars do indeed flex on the road.
RST wrote:It really does make sense to get proper new seals.![]()
I remember on my first T-Bar
-it started off as a drip, then a torrent.
I pulled Gaffer tape, silicone and all sorts of guff packing out of there.
Just bite the bullet and get new seals
+ eccentric rods.
I know allot of guys with T-Tops say they avoid the hassle at T-bars and moonroofs always leak bla bla, but there is something very nice about it chucking down, looking up and seeing daylight without bothering about getting wet!
It's well worth it.
Race Idiot wrote:The solution is to buy a tintop car!![]()
ick??..
Black bags on seats to collect water and empty each time i use it[Mr.
Green]
planted1 wrote:I have new seals and mine still leaked,
i fitted new eccentric guides and mine still leaked,
all four drain holes and drain tubes were blocked,
i cleaned them out and its a helluva lot better.
david123 wrote:planted1 wrote:I have new seals and mine still leaked,
how did you unblock the holes? and tubes?
