[Mk2] [NA] Eaglet LLC green coolant ok to use?
dubsport01
Post by dubsport01 »
Recently came across a bottle of Eaglet Long Life Coolant green. Everything on the bottle is in Japanese so i've no idea whats in it. anybody used this stuff before or know if its ok to use?
Ive tried a google search but go nowhere.
going4the1
Re: [Mk2] [NA] Eaglet LLC green coolant ok to use?
Post by going4the1 »
The fundamental requirement is that any coolant used must be ethylene glycol based. If you can confirm that you will be fine.
dubsport01
